I am using ANSYS R19 and would like to have the ‘help’ installed locally. Is it possible to install it from the Download Center?
Tagged: 19, General, mechanical, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantYes, it is possible and this is the procedure to follow: 1.Log in to the ANSYS Customer Portal 2.In the upper toolbar, click on “Download†and then select “Current Release†3.Specify the operating system you are using 4.Expand “Toolsâ€, click on “Local Help†under “Documentation†and download the zipped folder 5.Unzip the folder and follow the instructions provided in the file “Installing_Local_Documentation†to complete the procedure
