I am trying to run the Cartesian Shrinkwrap tutorial in ANSYS ICEM CFD 11 SP1 on a 64-bit AMD opteron platform with 64-bit Linux installed. This tutorial is described in the online ANSYS ICEM CFD 11 SP1 Tutorial Manual under CFD Tutorials > Geometry Creation > Geometry Simplification using Shrinkwrap. I get the following message: =========================== Error An internal error has occurred: Can’t find program “hexcart” in directories: /share/apps/ansys_inc/v110/icemcfd/linux64_amd/icemcfd /share/apps/ansys_inc/v110/icemcfd/linux64_amd/icemcfd icemcfd You can report this error to the maintainers of this software, skip the error and continue working, or view a stack trace ===========================
- Geometry Creation > Geometry Simplification using Shrinkwrap. I get the following message: =========================== Error An internal error has occurred: Can’t find program “hexcart” in directories: /share/apps/ansys_inc/v110/icemcfd/linux64_amd/icemcfd /share/apps/ansys_inc/v110/icemcfd/linux64_amd/icemcfd icemcfd You can report this error to the maintainers of this software, skip the error and continue working, or view a stack trace ===========================" target="_blank" rel="nofollow" title="LinkedIn">
- Geometry Creation > Geometry Simplification using Shrinkwrap. I get the following message: =========================== Error An internal error has occurred: Can’t find program “hexcart” in directories: /share/apps/ansys_inc/v110/icemcfd/linux64_amd/icemcfd /share/apps/ansys_inc/v110/icemcfd/linux64_amd/icemcfd icemcfd You can report this error to the maintainers of this software, skip the error and continue working, or view a stack trace ===========================" target="_blank" rel="nofollow" title="whatsapp">
- Geometry Creation > Geometry Simplification using Shrinkwrap. I get the following message: =========================== Error An internal error has occurred: Can’t find program “hexcart” in directories: /share/apps/ansys_inc/v110/icemcfd/linux64_amd/icemcfd /share/apps/ansys_inc/v110/icemcfd/linux64_amd/icemcfd icemcfd You can report this error to the maintainers of this software, skip the error and continue working, or view a stack trace ===========================" target="_blank" rel="nofollow" title="reddit">
- Geometry Creation > Geometry Simplification using Shrinkwrap. I get the following message: =========================== Error An internal error has occurred: Can’t find program “hexcart” in directories: /share/apps/ansys_inc/v110/icemcfd/linux64_amd/icemcfd /share/apps/ansys_inc/v110/icemcfd/linux64_amd/icemcfd icemcfd You can report this error to the maintainers of this software, skip the error and continue working, or view a stack trace ===========================" target="_blank" rel="nofollow" title="facebook">
March 17, 2023 at 9:01 am
FAQParticipantThere are some files missing from the 64-bit Linux ANSYS ICEM CFD 11 SP1 installation for the AMD Opteron platform, including the hexcart executable. The missing files are attached to this Solution. Save this file in the folder /…./v110/icemcfd in your ANSYS ICEM CFD installation. In this same folder extract the contents using the commands: gunzip filename.gz tar –xvf filename This should result in the files (including the hexcart file) being copied into the /…./v110/icemcfd/linux64_amd/icemcfd/ folder.
