I am getting error “Unable to load project ‘C:xxxx.wbpj’: System.UnauthorizedAccessException: Access to the path ‘C:xxxx_filesdp0designPoint.wbdp’ is denied.
Tagged: 19.2, General, structural-mechanics, workbench platform
May 15, 2023 at 8:32 am
Solution
ParticipantThis seems the access issue to the files. You may have access to the location but you also need to check the properties of the files at the location for the permission. Please check with your IT team to get full control for the all the files and sub folders.
- How to resolve “Error: Invalid Geometry”?
