January 31, 2023 at 9:25 am
FAQParticipantOFF を推奨しております。(Turn off Hyper-threading) 英語の資料となりますが、以下の資料の P1 にございます EBU (Electronics) の項目をご参照ください。 《参考資料》 #2041327「HARDWARE INFORMATION DOCUMENT Updated at ANSYS release 2021 R.x」 https://support.ansys.com/knowledgeresources/getfile?fn=2041327-R2021.x-hardware-all.pdf&fp=/solutions/attach/2041327-R2021.x-hardware-all.pdf キーワード: ハイパースレッディング,同時マルチスレッディング, Hyper-threading Technology, HT Technology, HTT
- [info] Failed to delete temporary files on server ‘localhost’. Found File ~ . You may want to manually delete directory ‘~’.
- [error] Solving adaptive frequency …, process hf3d error: Matrix solver exception: file I/O failure.
- [error] Doing Multiple Region Initial Mesh Assembly, process mesh3d : Unexpected internal software error. Please contact Ansys technical support
- [info] Normal completion of simulation on server: Local Machine.
- MPI 分散計算が行えない場合のチェック項目
- 一台の PC に複数の NIC (Network Interface Card) が有効な場合の Intel MPI の必要設定について
- [warning] For magnetic materials it is recommended to solve for at least 5 inductance passes.
- [info] Failed to start next variation. Analysis will stop when all running variations are finished.
- [error] Auto Solver Setting is not supported by Manual HPC Settings. というエラーが出て解析できません
