June 5, 2023 at 7:04 amFAQParticipant
There may be some issues probably due to small dimensions, in transferring geometry to Mechanical. The workaround is prepare a scaled up geometry in DM and then scale it down in the Mechanical stage using NSCALE command. One can export the scaled down model in .CDB format and read in External Model for further analysis.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
