How to verify that a the Rosin-Rammler diameter distribution for particles in a Fluent DPM sample is well-represented.
Tagged: 2019 R1, dpm, fluent, fluid-dynamics, MP - Particle Tracking, post-processing
March 17, 2023 at 1:11 pm
SolutionParticipantThis can be done using the DPM Sampling utility that samples all particles crossing a plane or outlet. Please see the attached document.
1. 2058394_Check_Rosin-Rammler.pdf
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
