How to use UDM values from one Fluent case and data file as initial value for another case and data file?
May 15, 2023 at 8:32 amSolutionParticipant
Please refer to attachment to access the solution. Keywords: udm, patch, interpolate, uds
1. 2054272.pdf
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
