March 17, 2023 at 8:58 am
FAQParticipantUse groups to define a set of selected objects (named selection) or to setup driving dimensions. 1) Select a set of objects and click Create NS in the Groups panel to save the selection for future use. 2) Create a ruler dimension in the Pull or Move tool and click Create Parameter in the Groups panel to save that dimension as a driving dimension.
- Skewness in ANSYS Meshing
