March 17, 2023 at 2:15 pm
FAQParticipantWhen applying a range function (for example: YAtXVal) to a transient report, the variable X always represents time. To use a different variable, two or more nested functions must be used. For example, the torque at position 100deg can be calculated using the following expression: YAtXVal(Moving1.Torque, XAtYVal(Moving1.Position, 100deg)) Now XAtYVal(Moving1.Position, 100deg) returns the time instance where the position equals 100 degrees, and this time instance is then used in the function YAtXVal.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
