- All Categories
- Fluids - Postprocessing
- How to use “file/data-file-options” to export only required variables instead of all variables to reduce data file size?
June 6, 2022 at 8:33 am
FAQParticipantThe command “file/data-file-options” will add the variables to export to standard list. So it will increase data file size. To export the required varaibles, please use File –> Export –> Solution Data option. For transient export you can use File –> Export –> During Calculation –> Solution Data. The corresponding TUI commands are /file/export and /file/transient-export.
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Scene and Animation Creation
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- Add Annotation to Graphics Display within Fluent
- How can I hide the legend or colormap for a Fluent plot?
- How do I automatically export figures generated in CFD-Post from Workbench?
- How do I display a vector or contour and the mesh lines together via TUI command?
