June 6, 2022 at 9:58 am
FAQ
ParticipantIf an expression is created for a parameter which has units using only dimensionless parameters, it will give error. If more than one dimensionless parameters are used, then create the expression inside the bracket ( ). Write the unit next to the expression in bracket [ ]. If parameter is equal to dimensionless parameter, then create an expression which divides/multiplies the custom parameter by 1 inside the bracket ( ). Write the unit next to the expression in bracket [ ]
