March 17, 2023 at 8:59 am
FAQ
Participant1. Create a script 2. Publish the script as a group 3. Right click on the group and select Create Parameter. This will create Parameter1 by default 4. Create an arbitrary variable in the script as follows: variable = Parameters.Parameter1 5. The Parameter1 value is now assigned to “variable”.
- How to resolve “Error: Invalid Geometry”?
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
