How to transfer the body force density from Maxwell Magnetostatic analysis to Mechanical Transit Structural Analysis system as an impulse loading
March 17, 2023 at 1:11 pm
Solution
ParticipantPlease refer to the attached file for more details of the solution
1. 2052137.pdf
2. 2052137.zip
