June 5, 2023 at 7:05 am
FAQParticipantOnce can do this by exporting an XML file for the material(s) of interest. To do this, 1. Select the material by a single left click (or hold the Cntrl key to select multiple materials) 2. Go to File > Export > Export Engineering Data 3. Save the file to a location on your hard drive. This will create an XML which contains the data from all the selected materials. In order to import this into a new Analysis system, 1. Go to Enginerring Data in the target system 2. Go to File > Import Engineering Data 3. Browse to the XML file generated earlier and click OK. This will import the materials into the new system.
