Tagged: 17.2, Drawing, Electromagnetics & Electronics, hfss, modeler
May 25, 2023 at 7:30 am
SolutionParticipantPlease see the attached pdf for the details 1.Select the arm (sheet) > right click> Edit > Surface > Thicken Sheet… Enter a variable named Thick and then enter the value (0.01cm) for the variable (as shown below)
1. 2043140_How%20to%20Thicken%20sheet.pdf
- Cloud Computing from Electronics Desktop
- How to enable GPU acceleration in Electronics Desktop?
- How to import/export an Ansys Maxwell model in Workbench?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
