Tagged: 16.2, fluent, fluid-dynamics, MP - Eulerian MP Flow, multiphase, phase-change
January 25, 2023 at 7:17 am
FAQParticipantThe standard state enthalpies of vapor and liquid phase are set such that their difference equals to latent heat of vaporization. The unit of standard state enthalpy is kj/kmol and usually the latent heat value is available in kj/kg. While specifying it here, multiply that value by molecular weight. We recommend using the saturation temperature as the reference temperature and the values of standard state enthalpy and other material properties at this saturation temperature for vapor and liquid or building their difference which leads to the latent heat at the saturation temperature. If the values of standard state enthalpy as well as the isobaric heat capacities are known at another temperature we can set this known temperature as reference temperature and employ the related enthalpy and other material properties values. In this case we have to provide the system pressure.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
