June 6, 2022 at 9:58 am
FAQ
ParticipantThis should be done through OUTRES,,%array% command. Here is an example :
OUTRES,erase
*dim,t_out,,5 ! RESULTS OUTPUT TIME ARRAY
t_out(1)=0.12,0.45,0.62,0.85,1
OUTRES,all,%t_out% ! OUTPUT RESULTS AT TIME SPECIFIED BY THE ARRAY
Key times in the array parameter must appear in ascending order. Values must be greater than (or equal to) the beginning values of the load step, and less than (or equal to) the ending time values of the load step.
