June 6, 2022 at 8:33 am
FAQParticipantTo specify such an injection you should provide a profile file as follows:
((injectionflowrate transient 12 1)
(time 0.0000 0.0001 0.0030 0.0031 0.2500 0.2501 0.253 0.2531 0.5 0.5001 0.503 0.5031 0.75 0.7501 0.753 0.7531 1.0 )
(flowrate 0.0 0.001 0.001 0.0 0.0 0.001 0.001 0.0 0.0 0.001 0.001 0.0 0.0 0.001 0.001 0.0 0.0 ) )
This profile would be read from File > Read > Profile and be selected for the Flow Rate of the injection.
The Start Time would be set to 0 s and the Stop Time to some big value, say 1000 s.
Note that a time of 1e-4 s is assumed to change the value from 0 to the required flow rate. This is done for the demonstration only and this time interval should be adjusted as per the need of your specific case considering time step size, flow rate values etc.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
