April 13, 2023 at 7:32 am
Solution
ParticipantContact interference can’t be directly handled within UI and you will need to insert ls-dyna keyword snippet. LS-DYNA interference keywords are: *contact_nodes_to_surface_interference; *contact_one_way_surface_to_surface_interference; *contact_surface_to_surface_interference. Syntax of these keywords can be found in LS-DYNA keywords manual. Attached is an example of modeling contact interference in WB
1. 2056575.zip
- How to resolve “Error: Invalid Geometry”?
