How to simulate the short circuit of a transformer using an external circuit in the Maxwell transient solver?
March 17, 2023 at 1:12 pm
SolutionParticipantWhen simulating a short circuit of a transformer using an external circuit in the transient solver, a time-varying resistance cannot be used. Instead, a switch can be inserted which has two different values of resistance: Roff and Ron. This switch can be driven either by a voltage or a current pulse, where the rise of the step pulse causes the switch to be activated therefore causing the resistance to change. See attached: Short_Circuit_switch.aedt Short_Circuit_switch.jpg Keywords: Maxwell transient, transformer, short circuit, switching
1. 2042958.zip
- Cloud Computing from Electronics Desktop
- How to enable GPU acceleration in Electronics Desktop?
- How to import/export an Ansys Maxwell model in Workbench?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
