March 17, 2023 at 1:12 pm
Solution
ParticipantThis documents demonstrates how to set up surface approximation in mesh operation, which will help controlling how close the mesh should be from the geometry. The mesh operation “surface approximation” is especially important when the geometry has true surfaces (round surfaces), which mesh should be as close as it can to the true surface in this case or information could be missing.
1. EM_FAQ_SurfaceApprox.pdf
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to create and manage a queue of simulations?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- Are solid losses and eddy losses the same in Maxwell?
- What are the available boundary conditions in Maxwell?
- How to calculate capacitance and inductance in Maxwell Transient solver?
- How to perform a material sweep?
