Tagged: 17, BCs & Interfaces, fluent, fluid-dynamics, General, materials, MP - Particle Tracking
January 25, 2023 at 7:17 am
FAQParticipantSet a porous-jump with the following properties: Face permeability = 10e10 m² Porous Medium Thickness = 0 Pressure-Jump coefficient = 0 Still in the Porous Jump panel, set the Discrete Phase BC Type to reflect
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- How do I use porous media in a multiphase flow?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
