Tagged: 18.2, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantBy default it saves calculated data only for the Current Design Point. However if you want to save it for other DPs as well you can click “Retain” for all at once or “Retain” for selective DPs. This option is available at the Table of DPs under Parameter Set.
