June 5, 2023 at 7:05 am
FAQ
ParticipantGo to ‘Measure’ tab, then select ‘Normal’ tool. Now select all the surface bodies, it will highlight the surface normal for each of it. Select surfaces whose normal should be changes. Select ‘Normal’ tool. Right click in GUI window and select option ‘ Reverse Face Normal’
