General
General
How to restore the original solid geometry of a beam object in SpaceClaim?
    • SolutionSolution
      Participant
      Description The attached pdf document explains how a beam object extracted in SpaceClaim can be converted back to a solid geometry. In order to achieve this, the operations Clip with Volume and Extract Geometry have to be used. The pdf document shows first how a beam is extracted from a solid geometry (steps 1-2 of the attached document) and then how the beam is converted back into a solid (steps 3-6).
      1. 2050655.pdf
