January 25, 2023 at 7:34 am
FAQParticipantOne can recover the Mechanical/Simulation data by doing the following: In the project folder, there should be a SYS.mechdb file for each Analysis object that was on the schematic: 1. Make a copy of SYS.mechdb to another folder, 2. Rename the copy to SYS.mechdat 3. Create a new Project. 4. File > Import, change the extension filter to .MECHDAT 5. Browse to the SYS.mechdat and open.
