Tagged: 10, General, structural-mechanics, workbench platform
March 17, 2023 at 9:00 am
FAQParticipantTo remove a material from the favorites: 1) Import the material into the engineering data project. It will then appear under the Materials folder. 2) Right click on the material name under the Materials folder and uncheck the Favorite Source item.
