March 17, 2023 at 8:59 am
FAQ
ParticipantWe can use the ‘Reduce’ tool in the ‘facet’ tab to decrease the the total number of facets in the selected area. Note that it’s not going to merge them into a single face. From the Facet tab, in the Adjust group, select Reduce.
