How to read solar load data files from serial ANSYS Fluent versions before 18.2 in a newer serial version?
June 5, 2023 at 7:06 amFAQParticipant
You can read solar load data that were written with a serial version of ANSYS Fluent that is older than 18.2 with the text command /define/models/radiation/solar-parameters/autoread-solar-data See Fluent 18.2 Migration Manual and Fluent User’s Guide, chapter “Automatically Reading Solar Data”.
- Defining heat transfer coefficient (HTC)
- Simulating Battery Pack Cooling System Using Ansys Fluent
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- What is the difference between internal and external emissivity?
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Where do I enter radiation properties such as emissivity/absorptivity, are there any recommended values for certain surfaces, and where do I find them?
- How to set up a heat source in CFX in a subdomain that results in a constant temperature
- What are the TUI commands to enable / disable Shell Conduction?
