June 6, 2022 at 10:32 am
FAQParticipantSometimes, you may want to display or even change the attributes of certain zones. When doing this, if there are many target zones, it can be difficult to select a particular zone. In these situations, it is useful to use the Selection Helper function.
Example: Display zones whose name begins with wall.
1. Launch Selection Helper from the Display category
2. Select the By Zone Name option and set the Zone Type to face
3. Enter “wall*” in the Zone Name Pattern
4. Zones, whose names start with “wall”, are selected The Selection Helper function supports all panels, including Display, Manage and Domains.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- Create Sections in Meshing
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- ANSYS ICEM CFD: Basic Blocking
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is the difference between patch dependent meshing and patch independent meshing?
