March 17, 2023 at 8:59 am
FAQParticipantSolution: Select Fill tool and then select all the edges using box select. This will quickly create a single surface for all the edges. Though a single surface is created, it will have the imprints of all the edge loops present in the model. Now, if you select that single surface and then right click and select “Detach All”, all the closed regions will separate out into separate surfaces.
