Multiphase Flows
Multiphase Flows
How to print Additional Data (eg. Heat Transfer Coefficient) along the Fiber Length in the FLUENT Fiber Module
    • SolutionSolution
      Participant
      By default, printing the fiber data writes out a *.his file containing basic information along the fiber length such as length, velocity etc. If you need additional data to be printed, such as heat transfer and mass transfer coefficients, it can be done by changing the following rpvar: (rpsetvar ‘udf/fm/extended-output? #t) Please refer to the attached document for further information and examples.
      1. 2046963.pdf
