Tagged: 17.2, Ansys nCode DesignLife, DesignLife, fatigue, General, nCode, structural-mechanics
August 25, 2023 at 12:16 pm
FAQ
ParticipantYou need to take the following steps: 1.Add a Static Entity Subset to the Analysis engine and specify the node numbers for output results. 2.Add a Time series output to file &/or pipe. 3.If the results are sent to a file, then specify the filename 4.If the results are sent to a glyph, via a pipe, then add a XYdisplay glyph to workspace and link the blue square on the analysis glyph to the xydisplay glyph. 5.Run nCode as normal – the results will be shown in the xydisplay glyph and a file will be created See the attached example
1. 2044863.zip
2. KM_nCode_How_to_output_stress_history.pdf
- How to resolve “Error: Invalid Geometry”?
