Tagged: 2019 R2, cfx, fluid-dynamics, MP - Particle Tracking, multiphase, post-processing
April 13, 2023 at 7:32 am
Solution
ParticipantPlotting particle slip velocities may be desirable to view separation regions due to particle inertia effects, particle slip near moving walls etc. Although particle slip is not directly available as an export variable from CFX, it can be defined as a new variable in CFD-post. Please refer to the attached document to access the solution.
1. 2060308.pdf
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the superficial velocity in multiphase flows?
- Mixing Tank Modeling in ANSYS Fluent
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- What do “incomplete” DPM particle tracks mean?
- How to obtain the input values for a Rosin-Rammler particle size distribution from measured data?
