March 17, 2023 at 1:12 pm
SolutionParticipantThis document demonstrates how to perform a parametric study region dimension in Maxwell, in order to determine an appropriate region size. The solving domain region has to be large enough to obtain correct solution, but at the same time as small as possible to reduce simulation time and memory. The appropriate solving domain region size depends strongly on the application, and if there are magnetic materials present in the model or not. This material also contains two 2D magnetostatic examples, but the same applies to 3D designs and other solver types as well.
1. 2063931.zip
2. EM_FAQ_ParameterizeRegion.pdf
- Cloud Computing from Electronics Desktop
- How to enable GPU acceleration in Electronics Desktop?
- How to import/export an Ansys Maxwell model in Workbench?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
