How to overcome situations when surface geometry objects in SCDM fail to translate into Icepak surface objects?
Tagged: 18, Basic Object Types, Electromagnetics & Electronics, General, geometry, icepak, Other
May 11, 2023 at 1:02 pmSolutionParticipant
When translating geometry in Spacelaim Direct Modeler into Icepak objects, it can happen that the surface in question is refused by the translator. Check the ‘Shape’ entry under ‘Face Type’ section of the ‘Property’ panel for the face. Only ‘Plane’ is a recognized ‘Shape’. If it reports ‘Spline’ do the following: 1.Got to Repair tab, Adjust section > Simplify tool This tool converts ‘Spline’ faces into ‘Plane’ surfaces After that the face should become recognized as a valid face for translating into Icepak face objects
1. 2055593.pdf
- Electrothermal Design of Power Converters for Electric Propulsion Systems – III
- ANSYS SpaceClaim: How to change autosave interval
- ANSYS Icepak: How to open an Icepak tzr or an existing Icepak project in Workbench?
- ANSYS Icepak: Computing Metal Fraction and Thermal Conductivity of a Trace
- Creating Icepak-Compatible Objects in SpaceClaim
- ANSYS Icepak: Importing Geometry Using Libraries
- Creating Icepak-Compatible Grilles and Openings
- ANSYS Icepak: Changing Materials For a PCB
- Importing BRD file in Classic Icepak
