March 17, 2023 at 1:11 pm
SolutionParticipantPlease find attached a document with detailed explanation of the steps to obtain the required input data for Rosin-Rammler particle size distribution: particle mean diameter and the spreading rate. These steps have been incorporated into the attached MS Excel data sheet where you can just input your mass flow rate / mass distribution data. Keywords: Rosin-Rammler, RR, spreading rate, mean diameter, particle, Lagrange, droplet, spray
1. 2062735.pdf
2. 2062735_RosinRammler-Parameters.xlsx
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
