How to obtain the current mass of particles in the domain while performing an unsteady DPM simulation?
Tagged: 19.1, fluent, fluid-dynamics, MP - Particle Tracking, multiphase, post-processing
March 17, 2023 at 1:11 pm
SolutionParticipantMass of particles in the domain at a current time-step or iteration, when using unsteady DPM can be obtained using either of the following methods: 1. From Report Definitions > New > DPM Report > Mass in Domain 2. Using Reports > Discrete Phase > Summary 3. Writing a particle history file from Particle Tracks Details on using these options have been discussed in the attached document.
1. 2056281.pdf
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
