March 17, 2023 at 1:12 pm
SolutionParticipantThis document demonstrates how to save the fields quantities during the parametric analysis, and how to display the field values. As Parametric analysis offers the possibility to sweep variables values and run a set of different simulations, field result could be saved in setup and plotted in post processing.
1. EM_FAQ_ObtainFieldQuantitiesfromOptimetrics.pdf
- Cloud Computing from Electronics Desktop
- How to enable GPU acceleration in Electronics Desktop?
- How to import/export an Ansys Maxwell model in Workbench?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
