January 25, 2023 at 7:17 am
FAQParticipantFor modeling a filter, where particles clings, you need a porous media to model the pressure drop and filtering characteristics and Lagrangian Particle Tracking-Model for modeling the particles. The absorption of particles can be taken in account by adding a subdomain to the porous domain. In the subbomain-tab fluid sources set the minimum absorption diameters to a constant value. All particles with a diameter below this value disappears from the calculation.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
