Tagged: 18.1, General, mechanical-apdl, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantYou can maximize the screen to full through GUI and command. The screen will have some space for menu options and tool bars as well. But if you don’t want them, you can drag the Bar above the GUI upwards to make it bigger. Through GUI: PlotCtrls-> Window Controls -> Window Layout -> Window Geometry -> Full Through Command : /WINDOW,1,FULL /REPLOT where 1 indicates the window number. Refer: help/ans_cmd/Hlp_C_WINDOW.html
