June 5, 2023 at 7:04 amFAQParticipant
Couple the DOF for all the nodes on the face using Remote Points having coupled behavior. Activate only those DOF which needs to be same.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
- How to define frictional coefficient as a function of relative sliding velocity
