April 13, 2023 at 7:33 amSolutionParticipant
As long as you move a component into another component, the instancing should remain. Instancing is based on components not bodies. If you move the body, then instancing is lost.
1. 2051459.zip
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
