How to include the effect of turbulence from flow onto the particles while using DEM? I am using Large eddy simulation for turbulent flow modeling.
Tagged: 18.1, fluent, fluid-dynamics, MP - Particle Tracking, multiphase, Other
June 5, 2023 at 7:06 am
FAQParticipantIt recommended to use the ‘Discrete Random Walk’ model for capturing effects of turbulence while using DEM. Discrete Random walk should be switched on for all cases, RANS, LES and DNS. It should be included only when subgrid models are applied. Keywords: dem, drw, discrete random walk, les
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- Hydrodynamics and Wave Impact Analysis
