General
General
How to improve performance when MAPDL gives error “optimally out of core memory”? How to configure in-core memory mode?
    • FAQFAQ
      Participant
      The memory allocation in MAPDL is dynamic so usually if the solver is running optimally out-of-core it is because it could not allocate enough to run in-core. So the first step would be to review the solve.out for the analysis and see just what the memory numbers were. There might not have been enough RAM to solve in-core. However user can manually control the memory mode using BCSOPTION command.
