May 25, 2023 at 7:29 am
SolutionParticipantFirst, if you faced some issues that not all variations are solved, you can use new mechanism that allows you to set a number of attempts before solver will give up. You need to use new batch option LargeScaleDSO/FailedVarRetryCount. Second, if you have seen that variations on some node are already finished, but on other machines there are still plenty of design points to solve, you can use LargeScaleDSO/VarRedistribution this will automatically redistribute variations and maximize utilization efficiency for more info please read help: https://ansyshelp.ansys.com/Views/Secured/Electronics/v212/en/home.htm#../Subsystems/HFSS/Content/HPC/LargeScaleDSOCommandLineSyntax.htm?Highlight=FailedVarRetryCount%20 and finally, in release 2021R2 an option LargeScaleDSO/SleepBetnEngines=5 was enabled by default. it will set a delay of 5 seconds between start of each LS DSO engine (not between each design point, so this time is nothing compared to total sim time) this will prevent fail of variations on start all options with description you can find in UI while submit a job: see attached screenshot
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
