January 25, 2023 at 7:16 am
FAQParticipantFor complex cases with many cell zones and non conformal interfaces the convergence of scalar equations may become slow, taking many iterations to obtain a steady state result. This can be improved by activating a solver stabilization method. The potential solver as well as user scalars are using the Fixed cycle method in the AMG solver, without any stabilization method. In the Advanced Solution Controls either BCGSTAB or GMRES can be selected for stabilization. Both result in faster convergence at the cost of added CPU time.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
