May 11, 2023 at 1:02 pm
SolutionParticipantThis document demonstrates how to export field result from Maxwell to a data file, import the data file back to Maxwell and display as field result on the geometry. Since data file could be edited in external tool like Excel, the revised field result could be reimported back into Maxwell.
1. EM_FAQ_ImportDataFiletoPlotFieldOverlayinMaxwell.pdf
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
