Tagged: 2019 R1, General, mechanical, modeling-and-meshing, structural-mechanics
April 13, 2023 at 7:33 am
Solution
ParticipantFrom Workbench, we can import a .msh in a Mesh component. However, it cannot be transferred to ANSYS Mechanical, only to Fluids products. To import a .msh to ANSYS Mechanical, we can use an ‘External Model’ component. We double-clik on the its ‘Setup’ cell and browse to get the .msh file. Then, we can drag and drop a Mechanical analysis template and share the External Model component data in the Model cell. An example is provided in attachment.
1. 2058075.zip
