How to get the computation time for dense particle (DPM) tracking in a Fluent job running in parallel?
Tagged: 17.2, fluent, fluid-dynamics, MP - Particle Tracking, Other
June 5, 2023 at 7:05 am
FAQParticipantUse the text user interface (TUI) command /parallel/timer/usage to get a list of time of different solver stages. Here you will find the DPM wall-clock time per iteration as well as the total DPM solve time.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
